Does this look right?
howelldw
Post by howelldw »
I ordered a tailwheel spring/chain kit from Univair for my '48. The replacement springs are about double the diameter of what is on it.
Is this correct or did they send me the wrong thing? I wanted to make sure that it was right before I installed them.
Also, the chain is about 4" too long. What do ya'll cut it with to shorten it down?
schnepel
Re: Does this look right?
Post by schnepel »
It is if your aircraft is equipped with a Scott 3200 tailwheel. Smaller diameter springs are utilized on the solid rubber Scott 2000, seen on the C-170's smaller cousin, the Cessna 140/120 and some C-140A's.
howelldw
Post by howelldw »
Yes, It has the scott 3200 tailwheel.
What does one use to cut the chain with? A dremel?
schnepel wrote: Thu Feb 13, 2025 12:14 am It is if your aircraft is equipped with a Scott 3200 tailwheel. Smaller diameter springs are utilized on the solid rubber Scott 2000, seen on the C-170's smaller cousin, the Cessna 140/120 and some C-140A's.
brianm
Post by brianm »
Diagonal cutters will do fine. If you only have a little bit to shorten you can open up the last link and remove it from the previous link and repeat.
Brian M
N2669V - '48
howelldw
Post by howelldw »
R. Thanks for the info.
brianm wrote: Thu Feb 13, 2025 1:45 am Diagonal cutters will do fine. If you only have a little bit to shorten you can open up the last link and remove it from the previous link and repeat.
