Tires with wheel pants
any magic for easy filling tires with wheel pants in place?? thanks. 3488D
Wheel Pants
I had two planes in the past that had little doors in the wheel pants which allowed you to access the valve stem. My current plane has 8:00 tires and no wheel pants. I think you may can get the little doors at either Wag Aero or Spruce.
Harold H
Harold H
I have the orginal-type metal wheel pants. Here's how I do it:
Roll the airplane to the point that the stem is at the 6 o'clock position, and using a tire pencil make a small ^ on the sidewall so as to more easily identify the stem in the future. When checking/filling with air all one must do is roll the tire to that point and remove only the AN-5 bolt that holds the outer pant-panel to the axle-end. The pant may then be pulled gently away from the end of the axle, leaving enough room to check pressure or add air. When finished, re-install the AN-5 bolt and you're through. I keep a tire gauge and small 9/16 box wrench in my baggage. (Along with a light, $5 foot pump, $2 tube-patch kit, and a 20-cent, plastic, valve-stem extension to check/add air to my tailwheel, all found at WalMart.)
- wa4jr
I also have the original metal wheel pants on my 54' 170, and am able to check pressure and fill the tires by rolling the plane to a point where the fill tubes are at the 7 to 8 o'clock position. I can do the operation without removing any bolts at all, though the space is somewhat limited. Of more concern to me with the wheel pants is that I cannot do a good tire inspection during the preflight. That worn flat spot can stay hidden for an long time before going BLOOOEEEE!
So I am thinking of taking the pants off, especially since winter ops are near.
Thanks for the info. i think the pants are so cute so will struggle with them. larry
At 170-speeds I don't have my wheel fairings on for speed. I have them on to keep mud, water, gravel, rocks, etc. off the undersides of my wings and tail. I remove them completely every so often (at least bi-annually or 50 hours) to inspect tires, wheels, and brake linings. If a tire won't make it 50 hours on the grass strip I live on, then it's time to throw them away.wa4jr wrote:I also have the original metal wheel pants on my 54' 170, and am able to check pressure and fill the tires by rolling the plane to a point where the fill tubes are at the 7 to 8 o'clock position. I can do the operation without removing any bolts at all, though the space is somewhat limited. Of more concern to me with the wheel pants is that I cannot do a good tire inspection during the preflight. That worn flat spot can stay hidden for an long time before going BLOOOEEEE!So I am thinking of taking the pants off, especially since winter ops are near.
