What is it?
W.J.Langholz
What is it?
Post by W.J.Langholz »
Can any one guess what this is. The guy that climbed out of it is 79 and claims this is the only one in the US
1942 Stearman 450
1946 Super Champ 7AC
Re: What is it?
Post by 170C »
Looks like an Aircoupe got mixed up with something :mrgreen: :mrgreen:
pdb
Re: What is it?
Post by pdb »
Socata Rallye
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
W.J.Langholz
Re: What is it?
pdb wrote:Socata Rallye
Bingo!!!!! Is he correct that there is only 1 in the U.S. thats flying?
1942 Stearman 450
Re: What is it?
I hope so. :lol:
pdb
Re: What is it?
Post by pdb »
I don't think so but I could be wrong. We used to have one locally and I would be surprised if there weren't more flying around the States.
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
W.J.Langholz
Re: What is it?
It was fun to see how the leading cuff comes out on a rail for take off and then retracts after you get up some speed. ...W
1942 Stearman 450
15A
Re: What is it?
Post by 15A »
We've had one of those here @ Ktan for a long, long time.
Here's a pic of 'Hook' Rose with his Socata Rallye just after its paint job a couple of years ago.
Joe Craig
'56 C172 Taildragger N6915A
'46 Aeronca Champ N65HM
Re: What is it?
What is it? A gutless wonder. 3 seats and an O-200. The French probably designed it for three Louis LeBeau's. The FAA lists at least five Morane-Saulnier ms880B's in their registry--endangered but not quite extinct. Now what does this have to do with C-170's? The N number previously belonged to a 170B that ground-looped. http://www.ntsb.gov/ntsb/brief.asp?ev_id=81386&key=0
Kyle Wolfe
Re: What is it?
Post by Kyle Wolfe »
There is a more modern one just north of us at Faribault, MN. It's used to pull gliders. Not sure what it's got for an engine. I'll try to find out. But it has the same tail and airfoil - the cabin looks to be a bit different.
Kyle
54 B N1932C
57 BMW Isetta
Re: What is it?
I looked at one some time ago but what as I remember turned me off was the constant speed prop. I think the blades were wood/ composite and rare? They are a few up here but I would class them as exotic.
flyguy
Re: What is it?
Post by flyguy »
SUMBODIES MESSUPED BIGTIME *
N-number : N8840B
Aircraft Serial Number : 8-4601
Aircraft Manufacturer :
Model : ZENITH CH 801
Engine Manufacturer : SUBARU
Model : ALL MDLS A/B
Aircraft Year : 2003
Owner Name
Owner Address
:LAS VEGAS, NV, 89134-8945
Type of Owner : Individual
Registration Date : 25-Jun-2003
Airworthiness Certificate Type : Experimental
Approved Operations : Amateur Built
THE "NUMERS MITE HAVE BIN CHANGE TO PROTEK THE GUILTY :twisted:
* DATA FROM "LANDINGS.COM
pdb
Re: What is it?
Post by pdb »
N-number : N8840B
Well its still a Socata...
http://www.airliners.net/photo/Socata-R ... 1386706/M/
Pete Brown
Anchorage, Alaska
N4563C 1953 170B
Re: What is it?
N-number : N8840B
Or maybe is just dislexic.
N8840B is a Zenith.
N8804B is a MORANE-SAULNIER.
N-number : N8804B
Aircraft Serial Number : 4
Aircraft Manufacturer : MORANE-SAULNIER
Model : MS880B
Engine Manufacturer : CONT MOTOR
Model : 0-200-A
Aircraft Year : 1961
Registration Date : 28-Aug-2006
Airworthiness Certificate Type : Standard
Re: What is it?
c170b53,
You saw one of these airplanes with a Constant speed prop? Maybe they made some with a different engine. Someone mentioned seeing one towing gliders too. Surely there's no CS prop that would work on a Cont. O-200. I guess an O-200 could drag a glider off, but it must be a very marginal effort.
