If you're an expert, don't read any further - this is for us Special Pilots.
Well now I'm the first to admit I'm a Knucklehead, but I've recently come to the conclusion that I'll have to re-learn over and over. I've been a bit aggrivated for some time that I just couldn't land like I once routinely did. Seems like the plane just want's to drop out of the air, if I tried to land as slow as I used too. Well FINALLY, I learned to fly again yesterday. Don't know how I drifted away from the BASICS, but here's what I rediscovered.
Rate of Descent = Control by Throttle (RPM).
Airspeed = Control with Yoke and Flaps.
I set up at 1500 RPM through the whole landing pattern. Turned final at 2 notches on flaps and 60 mph (prob slower than norm 170). Made myself leave the Yoke alone and use the throttle to control descent (1500 rpm baseline) 450-500 fpm. Pulled 3rd or 4th flap notch to slow down to 50 mph, just before landing (full stall or wheel). Real shortly I'm flying to Cabool to show Carol Coats I can safely land a 170.
Alright - I'm open for thoughts, suggestions, and good discussion.
