Flew out to Marthas Vineyard this morning with the breakfast crowd (8 planes) and encountered a problem I've never been in. After crossing Woods Hole I contacted MVY tower with position, ATIS, and intentions. I was 6th plane out. (You can relate to that, right Ole Pokey?) Anyhow, a Cherokee contacts the tower with his intentions and POW, his mic gets stuck. No communication now. I switched to ground control and no response. I started circling at the shore line 5 miles out. After 10 minutes I was getting a little "impatient". Heard the fellow go thru his landing check list aloud (impressed
) , talked to his dog alot (Springer Spaniel
), and totally clueless that his mic was stuck. I felt it was getting a little crowded, so I headed for the tower. But got second thoughts... I was hoping for some light signals but realized that might be a far reach, so I banked out and went back to my previous position.
The Cherokee landed and shut down, and communication was back to normal. The controller did a fine job bringing us all in.
There was quite a back-up of planes trying to depart, so I came in a little hot behind a friend and I was comfortable with the distance I held, but just before touch-down, I get the "15A go-around"
Back in line behind 4 other in-bounds...
So, hind sight being 20-20, what should I have done?
Leave the area after I felt frustrated?
Hold the position I had last contact with the tower?
Everything worked out OK in the end, but what a "HEADS UP" for future flights!
And by the way, the Cherokee departed after me. After he was cleared for take-off, his mic stuck again
