OT Quiz: OK,,How do you START this thing??....
OK, all you motor-heads.... How many of you know how (that is....the proper sequence...) to START this thing? (The A-Model! Not the young-model!)
- Brad Brady
Re: OT Quiz: OK,,How do you START this thing??....
Retard the spark....set the throttle....If it has a 6 volt starter whearl it around until the engine catches then, advance the spark.....slowly...( I think there is something else in there.....but it has been a long time)......Brad
- Jimmy M.
I'd start with flowers, a nice meal and some liquor
Jim Martin
'46 Aeronca Chief, 160 hp ( homebuilt )
'56 170 square tail, 180 hp.
- Brad Brady
Boy it has been a long time.....No wonder I'm getting that Pfizer spamJimmy M. wrote:I'd start with flowers, a nice meal and some liquor![]()
Your picture brightened up a dull November day.
Thanks!
Thanks!
- blueldr
You know, this guy Jim Martin has the right idea.
- HawkerCFI
Most importantly, the cranker must keep the thumb on the same side of the crank as the rest of the fingers. More than one early model starter has been surprised and broken a thumb. Yes there are common sense rules to hand cranking the early autos just as there are for the early airplanes.
- W.J.Langholz
That will warm and old boy on a COLD January Day!!!!!!!!!!!!!!
Yaba Daba DOOOOO!!!!!!!
Look close right through the driver side window......would that be the mom looking a little p'd off
W.
W.
1942 Stearman 450
1946 Super Champ 7AC
- flyguy
"CHOKE" "CHOKE" YEH U FORGET THU "CHOKE" ITSA LIL SILVER NOB WAY OFER ON THE PASINGER SIDE. . . PULL OUT ALL TH WAY - -GO UP ROUND THU FRONT TO CRANK* THEN RUN BACK WHEN SHE FIRE AN PUSH IT IN. (thu choke dummy)Brad Brady wrote:Retard DUHH DUHH MUMBLE MUMBLE I think there is something else in there.....but it has been a long time).....
* MY MODEL "A"s NEVER HAD NO BATRYs - - WE ALLUS HAD TU GIT OUT THU CRANK AN WINE HER UP THAT AWAY, BUT LASTYME SHE DINT CRANK TOO GOOD
