1) I noticed the back seat configuration is different between some C-170 aircraft. If an aircraft has the bench seat in the back can it be removed/installed easily? Most of my flying will be without backseat passengers, but on occasion 2 little squirts will be back there. I have only seen C-170's with Atlee Dodge style seats in them, but noticed there are several for sale with 'bench seats' in the back.
2) If a C170 does not have long range fuel, do you have any estimates on installation of A) aux fuel wing tanks? or B) interior javellion tank (also wondering where inside the plane a javellion tank can be installed)
3) Anyone have experience with Aero R2800 retractable wheel skis on a 180hp 170?
4) Anyone have experience adding the 'extended baggage' mod on a C-170? Expense estimate?
5) I noticed C180 gear legs are a popular mod on 170's, but know there are different types of C180 gear legs. Is there are certain model/type of C-180 gear legs 170 owners use? What specific benefit do you get from this mod (prop clearance, toughness)? Again, if I were to add this mod what is the cost/ process? Do they simply bolt on, or is it more complex?
6) Any advice for me regarding C-170's is apreciated. What to look for; or what to avoid. Thanks.
TG
