Worth the effort to make even if you don't have a filter adapter because it can be used to remove the stock screen as well.
F&M Oil filter adapter AND THREAD DRIFT-LOL
I made a 1" square socket out of common square tubing. Welded an old socket to one end and had to relieve the inside of the square slightly to make it fit.
- 4583C
[/quote]
Something like this? http://www.sears.com/shc/s/p_10153_1260 ... ve+adapter You still have to adapt to the 3/4" male lug. An 8- or 12-point socket?
Yes that is what I used... turned it with a 3/4" crowsfoot on the torque wrench.
BTW, Have you poured any oil into your engine yet? The old adage is if a (insert engine make/model of choice) isn't leaking oil, then there isn't any in it.
You may be on to something there!
I was intending to follow Bruce's example but didn't think the 1" tubing I had on hand was heavy enough.
[/quote]
Re:
Well, here it is 3 days before leaving on a 2-week trip, and my frappin' F&M adapter is leaking AGAIN!cessna170bdriver wrote:I'm currently running the F&M filter adapter on my O-300A. I have also used the Cessna filter adapter in the past. (Sorry, but I don't have the part number handy.)
Afer running both types, quite frankly I think I like the Cessna filter adapter better. (YMMV of course!) It uses a jam nut on the adapter against the sump which makes it easier to hold the adapter in the correct orientation while torquing. The large hex jam nut on the Cessna adapter is easier to torque than the smaller square aluminum boss on the F&M. In my experience, the jam nut on the Cessna adapter is also much less likely to allow the adapter to loosen at the sump when removing the filter, a likely source of leaks. I end up having to re-torque the F&M about every other time I change the oil, a real PITA. Also, the Cessna filter has only one seal, an o-ring under the jam nut, as opposed to the crush washer and fiber seal on the F&M. One positive thing about the F&M (IMHO) is that you get a new bypass valve every time you change the filter.
I bought the Cessna adapter originally because that was the only approved filter that I knew of at the time (about 1990). As I recall, that adapter was about the same number of $ back then that the F&M is now. I haven't priced a Cessna adapter lately, but if you were now choosing between the two, I would imagine the price difference may make the F&M worth dealing with. In the meantime, I still have a servicable Cessna adapter...
To hedge my bets, I'm immediately going to see if F&M can overnight the fiber gasket and -28 crush washer (I'm out
Re: F&M Oil filter adapter
Miles, your recently ovhl'd engine likely had clean threads on the accy case...but just to be sure... As FM to also send you their cleanout tool. If there is ANY crud, carbon, damaged threads in the case, the FM Adaptor will not give the proper torque and may leak.
By my reckoning, it's after 10am in Borger Texas, and F&M isn't answering their phone. Does anyone have the size and/or part number and a source for the o-ring used on the Cessna adapter?
Well, F&M finally answered the phone, and I have the gaskets on their way overnight ($10 for parts, $20 for shipping,
). If the re-torque stops the leak without new gaskets, I'm gonna bring 'em with me and let George demonstrate their proper installation at the convention maintenance forum. George, bring your tools. I'll bring a camera...
Anyone see why this socket wouldn't work for torquing the adapter? Is IS 1", isn't it?
I don't see any reason it wouldn't work after the temperature gauge adapter is removed. I made my own by welding a 1" ID square tube to a socket. You could also use a 1" crows foot if you figure the torque for the offset. A socket is the easiest however.
Don't know if this is available in store but it's worth looking into for $12 for a whole set rather than $32 for one socket you will use once every few years.
http://www.sears.com/shc/s/p_10153_1260 ... blockType=
Bruce,N9149A wrote:Don't know if this is available in store but it's worth looking into for $12 for a whole set rather than $32 for one socket you will use once every few years.
That set appears to be for hex fasteners; the filter adapter requires a square or double-square (8-point) socket. At the rate I'm going, I'll need to re-torque the adapter about once every year.
Another thought: Make me up a tool like yours in trade for all those crosswind landing gear parts...
With all the flying you'll do before BEH, you should plan on hiring the local shop to do an oil change, and while the oil is drained...they can replace the gaskets for you.cessna170bdriver wrote:Well, F&M finally answered the phone, and I have the gaskets on their way overnight ($10 for parts, $20 for shipping,). If the re-torque stops the leak without new gaskets, I'm gonna bring 'em with me and let George demonstrate their proper installation at the convention maintenance forum. George, bring your tools. I'll bring a camera...
You might have a deal there if you don't acquire one let me know.cessna170bdriver wrote:Another thought: Make me up a tool like yours in trade for all those crosswind landing gear parts...
As for the Sears set the search criteria was for 8 point sockets which would be square. I couldn't find it is the description but if you look close at the blown up picture I thought they did indeed look square.
Now that would defeat the educational purposes of the forum, wouldn't it?gahorn wrote:With all the flying you'll do before BEH, you should plan on hiring the local shop to do an oil change, and while the oil is drained...they can replace the gaskets for you.cessna170bdriver wrote:If the re-torque stops the leak without new gaskets, I'm gonna bring 'em with me and let George demonstrate their proper installation at the convention maintenance forum. George, bring your tools. I'll bring a camera...
Last edited by cessna170bdriver on Wed Jul 07, 2010 5:28 am, edited 1 time in total.
I'm not going to buy a tool before returning from Convention, so if you can whip one up, I'll take it. I tried a 1" crows foot, but my JASCO alternator would have to come off for it to work.N9149A wrote:You might have a deal there if you don't acquire one let me know.cessna170bdriver wrote:Another thought: Make me up a tool like yours in trade for all those crosswind landing gear parts...
For whatever reason, my computer at home won't enlarge the Sears socket set, but from what I can see they still look like 6-point. I'll take another look on my somewhat more modern computer at work.
Thanks for number 7 on the "reasons to keep your generator" list.cessna170bdriver wrote:.... I tried a 1" crows foot, but my JASCO alternator would have to come off for it to work.....
I know that's a joke, George,gahorn wrote:Thanks for number 7 on the "reasons to keep your generator" list.cessna170bdriver wrote:.... I tried a 1" crows foot, but my JASCO alternator would have to come off for it to work.....
