Best Mods for 170 STOL performance
Talked with a few guys, the sportsmans stol kit, VG's a sea climb prop were all mentioned...what have you guy used and found to improve short take off and landing performance? i know bigger tires on a cub really change the angle and help it off the ground at times..what about the 170..lets here some ideas.
Re: Best Mods for 170 STOL performance
The biggest single mod you can do to a 170 or any aircraft is put a bigger engine in it. In the case of the 170 that would be Lycoming 180 or Continental IO360. Of course that will cost you about $45k today.
Otherwise all the same mods you do to a Cub or any other aircraft you do to a 170 to attain STOL performance.
And just like any other aircraft the number one thing you can do is learn how to fly and get good at flying the aircraft you have. Hard to beat a pilot who knows his aircraft and is comfortable pushing it to the edge of the envelope.
All that Bruce said plus strip out as much weight as needed. Old wires, radios, foam, 30 pound back seats, pilot spare tire....
Since I've owned my 170 I've added a 80/42 climb prop, 26'' bushwheels + baby bush tailwheel, and a sportsman stol kit. For reducing the takeoff distance and increasing the rate of climb the new prop helped out the most. The sportsman stol kit is really great too, it allows you to approach a lot slower and the slow flight capability is much improved. I can make approaches using a little power at 45mph. It also allows you to climb out at a steeper angle, the new vx is 48mph. These two additions makes flying the 170 in the mountains at high density altitudes much more comfortable than before. Also I did notice with the 26'' bushwheels the plane will fly a little sooner with the increased angle of attack it allows. I love the way my plane is set up and it does a good job with the power available, but I would still like to put a bigger engine in it some day. Most airstrips are not a problem for me, but the time to climb at gross weight is too slow and I would also like more speed for cross country flights, right now I cruise at 105mph.
I'll second that statement, knowing your plane and how to fly it at its limit to get every bit of performance out of it is the best mod you can do.Bruce Fenstermacher wrote: And just like any other aircraft the number one thing you can do is learn how to fly and get good at flying the aircraft you have. Hard to beat a pilot who knows his aircraft and is comfortable pushing it to the edge of the envelope.
And of course shortly after that you buy the Skywagon you will have an even greater appreciation for the 170. Right Greg.bigrenna wrote:Of course by the time your done with all that, you will realize you should have bought a Skywagon.
- zenpilot
Strip out as much weight as you can. Add an 80-42 prop for some cash, a STOL cuff for a bit more cash. Spend the rest on dead dinosaurs (gas). Most of the good operators I know can fly ratty stock-ish aircraft a lot better than the guys with $100k Gucci rides who only fly on occasion...
I think I get what he is saying.....and I agree.bigrenna wrote:zenpilot wrote:Most of the good operators I know can fly ratty stock-ish aircraft a lot better than the guys with $100k Gucci rides who only fly on occasion...
Always such a silly argument and not helpful. It's right up there with "I know you are but what am I..." The question was how to get the best short field perf out of the airplane, not why a "good operator" is better than someone who can afford to have a nice airplane.
Good piloting skills outperform gadgets anytime.
But even the best pilot won't out climb a guy with a 360 under the cowl.gahorn wrote:I think I get what he is saying.....and I agree.bigrenna wrote:zenpilot wrote:Most of the good operators I know can fly ratty stock-ish aircraft a lot better than the guys with $100k Gucci rides who only fly on occasion...
But I also agree, the most cost effective thing you can do for STOL is piloting skills.
Unless the pilot with gadgets has good piloting skills toogahorn wrote:I think I get what he is saying.....and I agree.bigrenna wrote:zenpilot wrote:Most of the good operators I know can fly ratty stock-ish aircraft a lot better than the guys with $100k Gucci rides who only fly on occasion...
- zenpilot
Missed my point...for the money, unless you are going to spend the $65k for the big motor, you are better with the few basic changes, and a lot of time flying the machine. Valdez proves it every year. Guys show up with highly modified rigs, and get schooled by those with lots of experience. Horsepower only gets you out, skill gets you in, and judgement keeps you from confusing the issue. Judgement comes from experience.bigrenna wrote:zenpilot wrote:Most of the good operators I know can fly ratty stock-ish aircraft a lot better than the guys with $100k Gucci rides who only fly on occasion...
I stand by my original post. Get a prop, a cuff, and a bunch of time practicing, and your STOL work will be better than the guy with every mod floating around the interwebs.
i knew what you meant not sure why it got over analylized. just wanted to know ASIDE FROM PILOT SKILL what mods have been the most effective for your planes and performance...
