Takeoff Horsepower at given RPM
Re: Takeoff Horsepower at given RPM
FredMa wrote:was everyone typing at once or what? I see george beat me to the punch.
Yeah...I think we're all on the same subjecgt simultaneously. Richard even edited his post and it made my response seem misdirected until I also edited it.
Aryana wrote:Just give me a viable TCM IO-360 STC and I'll be happy. Oh, and while I'm dreaming I'd like it for the same cost as a O-300 please. :mrgreen:
I agree, if there was one out there, I would have done it instead of overhauling the old O-300. But, if just changing the pistons was indeed a good mod, I would do it now (but only if it was legal, George).
We haven't had a discussion this spirited in a long time!
The guy that I am, or was, acquainted with that had the bootlegged pistons in his O-300 seemed to be very well versed in the business and claimed to a lot of experience with that modification in the O-200 engines used in racing. When we met the first time, It was during the annual Swift fly in at my airport. At that time I had posted a for sale notice for a Continental IO-360D engine that I had in my hangar. That's a popular modification for the Swift too and he came down to look at the engine I had for sale. We spent quite a visit together. as I said, he seemed to be very well versed in what he had done. Unfortunately, he was unable to buy my engine at that time, The following year, during their annual fly in, he looked me up, but I had sold the engine by that time. I never thought to ask him if there was a possibility of interference if a valve stuck. I think maybe that was because I have never had a stuck valve and as a result I don't often think about them.
lowNslow
Post by lowNslow »
The O200 engines for Formula One are supposed to be stock. They way they get more HPs is to use a short prop and wind the engine up to 4000+ rpm.
lowNslow wrote:The O200 engines for Formula One are supposed to be stock. They way they get more HPs is to use a short prop and wind the engine up to 4000+ rpm.
WOW! They must really scream!
Most of us know that props lose efficiency at very high RPMs, partly because the tips go supersonic and the boundary-layer leaves them due to the shockwave. Shortened tips address part of that..but shortened props also are less efficient due to the simple loss of airfoil surface.
The high RPM (within reason) doesn't (or shouldn't) hurt our O-300s too much. After all, these same cylinders, pistons, rods, bearings, etc etc were used in the geared GO-300 which turn in the 3,200 RPM range and produce 175 HP.
But to deal with the propeller loss of efficiency, they put a gearbox on the nosecase to reduce prop RPM. So the engine
was allowed to turn up in the 3,200 range (and even higher) while the prop still turned in the 2700 range. Those props were pitched greater as well, and later engines even used constant speed props.
Regardless, it was an unpopular engine. It's higher RPM resulted in lower TBO (1200 vs 1800 hrs), more noise, more fuel consumption, and more expensive overhauls due to that gearcase. Flight schools did not enjoy them due to the fact that simple training manuevers were hard on the gearcase. (Stalls, especialy accelerated-stalls, Lazy-8s, steep turns, etc. placed high gyroscopic loads on the gears and resulted in increased wear. Pilots inexperienced with geared engines failed to keep them "spooled". The frequent power changes and descents under low power/reduced power caused the prop to "drive" the engine and chatter gears.)
Plus, the airplanes in which it was installed (Cessna SkyLarks, T-41s, etc) did not have much greater performance. A C-175 was called a "baby 182" by it's owners, but it only eperienced about 5-7 kts improved speed over the standard 172. Despite what I heard, my several hundred hours of personal experience in them demonstrated a 110 kt cruise speed, vs the standard 170/172 cruise of 105. (It takes lots more HP to move the same airframe faster due to the old rule-of-drag that increases at the square rate-of-velocity.) That was hardly a good trade considering it burned another 2 gallons or so per hour and lost 600 hours of TBO.
The field performance also failed to show improvement because they were heavier, partly due to that engine and partly due to unuseable fuel, the result of misshapened tanks and higher fuel-volume certifiation requirements. Cessna did their best to put lipstick on it but it never caught on, and only barely fit into a niche between the 172 and the 182. Yeah, it was a "baby 182" all right.....it had 182 operating expenses at 172 speeds and useful loads.
Cessna tried to lower the purchase cost in order to move them off the lot by cutting corners. Cessna introduced acrylic paint (a la automotive paints) and stopped interior corrosion-proofing. This reduced labor and matl's costs, but it resulted in filiform corrosion under the paint and interior surface degredation. That, and the engine, made the used-airplane sell cheaper and attracted lots of secondary owners to it.....whom were looking for low-cost flying. Unfortunately most of those type owners gave even less mx attention to an airplane which clearly needed MORE....not less.
Those engines are rapidly falling into the junk-piles now because there simply are NO thrust bearings available. No one supports that engine
That was my experience....and I actually LIKE the airplane. I was a "psuedo" partner in one for about 5 years and spent many days/hours working on it.
lowNslow
Post by lowNslow »
The GO-300 was what I thought of when reading about the Formula One engines. The trade of is they require a long takeoff run, kinda like starting off in your truck in fifth gear. TBOs are also in the 200 hour or less range.
The formula one engines are turned up a helluva lot higher than the GO-300.
I'm amazed the valves don't float running at 4000rpm or maybe they do and just don't hit the pistons.
The Continental valve lifters are similar to automotive Oldsmobile lifters from the 50's and 60's, and they don't "float" until RPMS reach above 5,000. (At least my uncle's Olds 98 would not float until then. We kids never told him about it, tho'.) :lol:
