I0-360 STC discussion?
johneeb
Re: I0-360 STC discussion?
Post by johneeb »
c170b53 wrote:I wonder why the set-up on a XP is not used? The tank fits below the floor on the right, the fuel pump under the floor L/H.
Jim, I do not know why either, I followed the drawings that came with the XP-mods STC.
For sure you follow the STC paperwork, but why in the development stage would they decide to go a different path than Cessna.
Post by 170C »
Isn't it true that some IO-360 installations have been done without a header tank? Someone told me that they just ran the fuel return line up the door post and into the left fuel tank. If that is true, one would have to burn fuel out of that tank first to prevent fuel overflow if the fuel tank were filled to capacity. Didn't sound like a good arrangement to me, but I don't know much about injected engines and their fuel systems. I have no idea how much fuel can be returned to a header tank, but it seems the fuel flow to the injection system must be a constant volume and if full engine power is used on take off & climb then very little would return, but with engine power reduced as in cruise or while idling that there would be quite a bit. On the TSIO-520 in my friends' C-206, he has two header tanks under the floorboard, one on the pilot side and one on the copilot side. This must be due to the 206 not having a "BOTH" selection on the fuel selector valve?
T. C. Downey
Post by T. C. Downey »
Acorn Welding ( http://www.acornwelding.com/productsEngineMount.htm ) quoted me a 3650.00 price for a new engine mount. IO-360-C to a C-170
bagarre
Post by bagarre »
T. C. Downey wrote:Acorn Welding ( http://www.acornwelding.com/productsEngineMount.htm ) quoted me a 3650.00 price for a new engine mount. IO-360-C to a C-170
That's the same price they gave me when I called them. It's based on the price to make the HawkXP mount.
Keep in mind, they can't give you any approval for that mount as they have no approved design drawings for it. You'd still need that from XPMods or other means of approval.
ak2711c
Post by ak2711c »
When I did mine Tom told me I could use ether style header tank but I wasn't too eager to pull my floor up so I went with the Maule style just for ease of installation.
Shawn
The IO-360 installations I've seen without a header tank run the fuel return up the door post and into the cross cabin vent line. There is no way to determine where the return fuel will go, either to the left or right wing tanks or to both, or maybe out of the goose neck. That's why I wouldn't consider an installation without a header tank so that the fuel returns to the header tank and then right back to the engine driven pump.
The probable reason that Tom Anderson used the Maule header tank was price. I paid only $90 for a new one from Maule. There is NOTHING sold by Cessna that cheap. They want something like $300 for a firewall shut off valve. Maule used a Ford truck valve costing about 1/10th as much.
If anyone needs a brand new Maule header tank, I have one I'd be delighted to sell.
bagarre
Post by bagarre »
Maule now wants $180 for their header tank.
When I ordered the header tank from Maule, Bruce, the parts man, said they didn't have one in stock but they would make one and send it. If the price has gone up that much, maybe I'll make a buck on it. The reason I didn't use it was because I found one in a junk yard that included the FWSOV for something like forty bucks.
bagarre
Post by bagarre »
Firewall shut off valve.
Yep!
falco
Post by falco »
for comparison, engine mount for a Falco from Sequoia Aircraft costs $3500. No certification. Also, a dozen years ago or so XP Mods was selling the STC and engine mount for $5K. (Tried to look up a price for Vans Engine mounts, not quoted separately on the website )
bagarre
Post by bagarre »
Also by comparison, a NEW engine mount for a Maule M5 220C (TCM IO-360) costs $980.00.
Might be easier to buy that and have the modification approved. There is a 337 on this site that did that.
avoight
Post by avoight »
There are a few rear engine mounts from 337's around for sale, even one from Acorn Welding. Usually go for about $1500.
'59 172 TD 220 Franklin mod, Horton STOL, ABI 26" mains, Baby Bushwheel TW and some other stuff...
T. C. Downey
Keep in mind, that when you buy the STC from Tom Anderson, you get the drawing for the mount,,,, you can have any one build that for you. Tom Anderson will actually give you a list of those who can do it.
