When the Northstar Loran units came out, I was not someone who rushed out to get one...I only acquired one in my third airplane because the installation had already been made and I wanted to fill the hole in the panel left when the previous owner insisted on keeping the box for his other (stored) airplane he'd inherited from his father...a Fleetwing Seabird!
Anyway....the Northstar only provided textual guidance...no "moving map"...except in the mind.....(SA). Many of my friends ridiculed me about being "behind" technology, and urged me to come into the present-time..... "Get a GPS! You'll LOVE the MOVING MAP."
I did. And I do. But....
The other day, in the simulator, I had a pair of clients who were truly talented aviators. They had no difficulty in the various maneuvers required for their Part 135 recurrency and we had actually finished the lesson a bit early with some time left to spare. We'd enjoyed the interaction ....(I believe in the philosophy that, in the sim, if you're laughing...you're learning. If you're not laughing at your discovered weaknesses/errors...if you're frustrated and overstressed by the experience...then you might as well come off-motion and go home because all learning has ended.)
These guys were having a good time, and with the extra time available, they challenged me to give them a "little extra".
They had thrown down the gauntlet.
(If you're interested in the details of this discussion, you'll want to study the approach plate for the ILS to Rwy 11L at Tuscon (KTUS). I failed the local radar and the glideslope. And the aircraft DME and FMS (Flight Managment System which provides GPS/moving map). The crew would have to use good-ol' basic navigation of VOR/Localalzer and ADF to take off and return to the same airport.
I set the weather to basic-VFR of 1,000 overcast and 3 miles visibility. No problem...right? (Hell! Lindbergh found Paris with a compass and a clock! You'd think an ATP-rated crew with thousands of hours in a modern jet airplane could takeoff and land at the same airport. RIght?)
With the aircraft taking-off on Rwy 29R, they were cleared to RYAN NDB, then to LIPTE intersection, maintain 6,000. Upon reaching LIPTE, "Cleared for ILS (localizer only) approach to KTUS."
I was never more surprised to watch this talented and experienced flight crew draw a bowl of spaghetti in the sky as they wandered all over the area searching for the inbound course. This crew had become so dependent upon FMS moving maps and ATC radar ...they became completely disoriented, required two missed approaches, wandered beyond the area for the MSA (Minimum Safe Altitude) and ended up in a (generally) downward-spiralling approach to a point 4 miles from and 2000' above the runway. They were waay behind the necessary descent rate, increasing their descent and worried about the terrain...about to go "missed" for the third time...
I had to instantily/drastically "raise the weather" minimums from published (virtually VFR)...to CLEAR/UNLIMITED....in order for them to see the runway sufficiently to land.... or we'd be up there still!
All they had to do was, Take off Rwy 29R, turn left to approximately WEST and proceed to the RYAN NDB, then fly NORTH via the RYAN bearing (about 350 degrees, right?) then identify when they crossed over the LOCalizer course, fly another 15 seconds, turn LEFT (Northwest) for a minute, then turn LEFT again to intercept the inbound LOCalizer course, and using RYAN NDB bearings, step-down at each intersection until reaching minimums, look up, see the runway and land.
Four turns and land the airplane.
It was a real eye-opener for all of us. It had seemed a simple navigation problem but this highly experienced crew discovered themselves so accustomed to moving maps...they'd completely forgotten how to keep Situational Awareness (SA) in their heads.
Don't let that happen guys. If you think YOU are immune..... then you'd better get with an instructor and hand him a challenge....to CHALLENGE YOU!
I hope it's a fun experience for you.
