Narco Escort 110 Manual or Pinout
- gfeher
Anyone have a manual or pinout for a Narco Escort 110 NAV/COM that I could buy or borrow? We don't have one in the MX Library. I have an old working Escort 110 that I might be able to use for a non-aircraft project. If you want to keep the manual, I'd be willing to pay the postage to send it to me, and I'll scan and promptly return it. Thanks.
Gene Feher
Argyle (1C3), NY
Argyle (1C3), NY
- gfeher
Re: Narco Escort 110 Manual or Pinout
Well, I found the pinouts from another source. Here they are:
The pins are numbered 1-15, with "1" closest to the center of
the rack and 15 at the outside edge. When you're looking at the rack
from the back, it's normal left-to-right numbering ("1" far left).
Pin Use
1 Ground (phones/mike/speaker)
2 Nav/Com receiver antenna center conductor
3 Nav/Com receiver ground
4 Transmit antenna center conductor
5 Transmit antenna ground
6 Speaker out
7 Headphones out
8 Right autopilot
9 Left Autopilot
10 Aux Audio
11 Dimmer
12 Mike key tip
13 Mike audio ring
14 Switched A+ (12V out)
15 A+ (12V in)
I'm still interested in borrowing a copy of the manual if anyone has one. Thanks.
Pin Use
6 Speaker out
7 Headphones out
8 Right autopilot
9 Left Autopilot
10 Aux Audio
11 Dimmer
12 Mike key tip
13 Mike audio ring
15 A+ (12V in)
Gene Feher
Argyle (1C3), NY
Argyle (1C3), NY
