C145 oil level
Richgj3
C145 oil level
Post by Richgj3 »
What level do you guys keep it at? Or to ask another way, where does it settle at?
Rich
Re: C145 oil level
When I change oil and filter I put in seven qts. I let it operate at 6, and add oil when it gets to 5-1/2. I keep an eye on oil temp and don’t ever see more than 220 on a gauge that goes to 245.
My engine throws oil out the breather at more than 7 and settles down at 6 over the next 3 or 4 hours. It will stay around 6 for the next five hours. The minimum operating according to TCM is 4.
Ryan Smith
Re: C145 oil level
Post by Ryan Smith »
No oil filter on my airplane. It likes to sit between 5 1/2 and 6. Anything much over 6 and it pukes out of the breather.
Richgj3
Re: C145 oil level
Post by Richgj3 »
Thank you for the info.
Rich
mit
Re: C145 oil level
Post by mit »
At one of Cont briefings the guy said fill it. I don't think anyone does.
Re: C145 oil level
mit wrote:At one of Cont briefings the guy said fill it. I don't think anyone does.
Relying on memory here.... I believe the certification basis for this aircraft and engine combination required that the engine sump hold sufficient oil to allow the maximum oil consumption allowable by the engine mfr’r to minimally meet the fuel-endurance of the airplane. Since Cessna claims this airplane has an endurance of 4 hours at maximum power...and TCM says that up to one-quart per hour is “allowable” and that four quarts is minimum operating quantity.... the sump holds 8 quarts.
KInda give you a warm, fuzzy feeling doesn’t it.... :roll:
Deputydog
Re: C145 oil level
Post by Deputydog »
I agree with George, I put in 7 qts and add when its dips below 6 qts.. If I put in 8, it seems to come out the breather and finds its way to the belly.
1950 Cessna 170A model
