Exhaust Risers too long??
oldtrucksrule
Post by oldtrucksrule »
Hey y'all, I'm clipping away on this motor. I got the risers ordered but, it looks as though they're too long. Is it possible I ordered the wrong length? I ordered the P/N's I found. Thoughts?
Re: Exhaust Risers too long??
We don't know what parts you ordered. Here is the parts pages.
Your looking for:
4 ea. 0550157-7
2 ea. 0550157-8*
Pipes are the same each side.
*corrected part number
oldtrucksrule
Bruce, Those look like the part numbers I ordered. I'll double check, Thanks!
oldtrucksrule
So, the part numbers I have are
2- 0550157-8
4- 0550157-7
Ah, judicious use of the speed color :D
oldtrucksrule
Thanks, I talked to the builder of the risers and they are going to build new risers custom to my exhaust. Very stand up and easy to rectify the situation.
The big question is, why is your exhaust CUSTOM? It should not be.
It certainly appears those risers do not meet spec. Who made them? Can they confirm they shipped the correct pn’s?
Looks to me like the flange on the #1/#6 riser wasn’t clocked correctly on the pipe.
cessna170bdriver wrote:Looks to me like the flange on the #1/#6 riser wasn’t clocked correctly on the pipe.
Even more obvious (it seems to me) is that they are ALL too long for a 170. They appear to be for a later 172. (C172’s after SN 55001 used different riser PNs although the same illustration was used in the IPC.... maybe to save artistry costs.)
oldtrucksrule
After reconsideration, I sent the risers back to the seller and went with AWI.
Thanks for the input
Joe Moilanen
Post by Joe Moilanen »
AWI is great, but I still had to tweek the bent riser on the pilots side to get it to fit right. Measuring how much more the bent riser (front one/#6 Cylinder) had to be bent, I bolted the riser flange to a piece of scrap flat bar, put a piece pipe that fit snuggly in the riser, heated it up at the bend and bent it to where it needed to be. I checked the amount that it moved by using a square from the scrap flat bar to the flange on the riser, marking on the flat bar before and after to check difference. It then fit perfectly, also used "muffler" tape on the clamp connection. No leaks.
4518C
The problem is where to place blame.... is it really the riser..? Or is it the muffler...? Or is it a cylinder exhaust flange out of spec....?
Just because what was removed seemed to fit... doesn’t mean the previous fitment wasn’t also needful of “malletizing”. Cylinders are fitted to crankcase/sumps with bolt and studs and there is a certain amount of “slop” that can exist in this entire sequence of castings, bolts/studs, cylinders, flanges, risers, mufflers.... Just sayin’. These things are rarely “drop in” replacements.
In any case, new risers being fitted to used mufflers often need careful fitting. I’ve had good success by loosely bolting them together and then snugging them up after they’re in-place.
Joe Moilanen
GAHorn wrote:The problem is where to place blame.... is it really the riser..? Or is it the muffler...? Or is it a cylinder exhaust flange out of spec....?
Exactly, a little bit of movement at the cylinder base equates to quite a bit at the muffler end of the riser.
