Worn rudder pedals 170b
Vertical
Post by Vertical »
My 55 170b rudder pedals have become very worn at the primary pivot point. The holes are ovalized and need to be addressed.
From research here I see some references of bushing these. See photo. Is bushing these locations possible?
I'm seeing some used pedals available online, but not much guarantee that they are in any better shape.
Alternately, I can buy the new style (certainly uglier) that seem to be approved on everything but the 170. https://www.mcfarlaneaviation.com/produ ... AP2000-01/
What are folks doing with these?
Re: Worn rudder pedals 170b
Where you have circled is exactly where most do wear and are usually bushed with simple doublers (about the size of a silver-dollar for those old enough to have any in their pocket) riveted.
Vertical
Post by Vertical »
Thanks. Doubler the same sheet thickness as original?
falco
Post by falco »
I found that my pedals were significantly worn (though not dangerously so) on the left side of the airplane, and nearly pristine on the right. While restoring the whole assembly, I just swapped them.
cheers,
Pete
Yes, looking at any airplane you can ascertain the health of the pedals (and the aircraft) at a glance much like looking at the pedals of a car to guess at true milage. Worn pivots on pedals will cause the pedal to tilt about their horizontal axis. Often the Pilot’s R/H pedal will tilt to the left as well, the pedals amount of “ clatter” when moved back and forth is another obvious indicator of the amount of wear present.
I would be scrounging around looking for replacements, even dismantling pedals (rivets) to find parts to restore a single pedal to serviceable status.
JohnNielsen
Post by JohnNielsen »
I found and install a set of pedals from a C180 and they look much more modern and not as slippy as the originals. Easy 337 minor change under CAR3 ref Cessna drawings for the early 180.
Vertical wrote:Thanks. Doubler the same sheet thickness as original?
If you prefer the “modern look” then later pedals might be an option, but they also will wear similarly.
I like the originals and would never replace my round tail with a swept or squared-off one. :twisted:
Here’s a couple pics of typical damage and repair:
Vertical
Post by Vertical »
A picture is worth a thousand words.. Thanks!
I like the original pedals as well. I'll run this by my mechanic. Hopefully he'll be ok with it... I don't suppose this is in the 100 series repair manual or similar?
JohnNielsen
These planes are built and TCDS approved under CAR3. That means AC43-13 is APPROVED data for repairs and modifications of these planes.
Vertical
Post by Vertical »
Thanks for the all the info. It's not as nice as the turned "top hat" bushing/doublers that one of the other members made, but this should buy these pedals a few more decades. I also spent about 10 hours crammed under the pedal with a toothbrush and solvent cleaning the rest of the control and brake assemblies. The sheet metal work was infinitely more enjoyable.
Looks very nice! Congrats!
