Compass Deviation Card
- rupertjl
Anyone know of a place to download a copy of a compass deviation card? I've searched all over and all I can find are explanations of the card itself. I bought a comapss rebuild kit and one came with it but I lost the darn thing. I just figured I could find one on the web somewhere and print it out.
Thanks in advance!
Jud
Thanks in advance!
Jud
If you are referring to the little 1" X 3/4" card that comes with repair kits, they may be found at aviation supply houses and instrument repair shops(usually just for the asking).
Or if you'll send me your mailing address via PM, I believe I have an extra I'll mail you.)
If you are talking about the 3 -1/2" long X 3/4" card that originally came in 53 and later B models, I had one mfr'd at a local engraver on acrylic. They reverse engraved it on it's back, I filled it with the appropriate color Tempo paint, and removed the gloss finish with a 0000 steel wool pad so it'd have a non-glare finish.
- N3243A
Just order one from Spruce for $1.85 or copy one from another aircraft.
Aside from the FAA regs that require one in the aircraft, who really uses these cards? Anyone? I could go on a rant here about the worthlessness of these stupid deviation cards because the magnetic flux of the earth is constantly changing (variation) to the tune of about 1/5 degree per year (depending on location) rendering the cards useless in 5 to 10 years, but instead I'll just ask if anyone finds them of value? Do you actually steer 89 degrees if you want to fly due East for example? What, your compass intervals are in 5 degree increments and are spaced only 1/8 inch apart and you have a hard time discerning 1 lousy degree to set your DG by? Well you get the idea...
Bruce
Bruce
HA! Who'da ever thunk it! Bruce and me on the same page!
I recently took my CFI-I renewal ride with the feds and he looked at my CDC (compass deviation card) and remarked, " Is that thing accurate? All the desired steering points are exactly the same as all the compass points!"
I merely said, "All the rule says is that I have to have one. If I want to go North, I point it North."
No further discussion occurred about it.
P.S.- I actually have taxiied all around the compass rose at the airport and the dang thing sure looks accurate, anyway! Don't ask me what position my flight controls were in at the time.
- N3243A
It's a simple thing, Bruce! To fly 272 degrees to get to Nowheresville...all you have to do is use 1992 Sectional charts ...so the magnetic deviation matches the last time the compass card was calibrated! (I'd love to see a Fed scratchin' his head trying to figure out how to write that one up!)N3243A wrote:This IS a real shocker!!! Ya know George, I was getting all prepared for you to give me a long story that by steering 272 degrees rather than 270 degrees saved your bacon 12 years ago on a 150 mile trip to Nowheresville TX and that I was all wrong as usual. Guess I'll have to "stand down".
- jrenwick
Re: Compass Deviation Card
I put together an Excel spreadsheet that prints one the right size for Airpath compasses. It's at http://www.eaa54.org/Ccard.xls if you want to use it. You enter your own N number and correction information and print a card with deviation numbers that might be easier to read than a hand-written one. You can also change the dimensions if what it makes doesn't fit your compass. Instructions are on the sheet.rupertjl wrote:Anyone know of a place to download a copy of a compass deviation card?....
Happy flying!
HEY!!! What's wrong with lookin' like you're in your Fifties!!??johneeb wrote:John, very nice. Our airplanes may be from the 1950s but they don't have to look that old.
Johneb
I follow the line on my gps.N3243A wrote:Just order one from Spruce for $1.85 or copy one from another aircraft.
Bruce
A friend once asked me to fly his Pitts from Homestead FL to Oak Grove TX. After taking off I realized the compass was wildly out of calibration, like 20-30 degrees ! So I overflew the runways at Tamiami airport and noted what the compass read on a piece of paper. This ad-hoc deviation card helped me to complete the trip with surprising accuracy. No radios, only that compass and previously cut and folded sectionals.
Rudy
Rudy
