Trying to get more hp out of a 165hp Franklin?
Has anyone ever put high compression pistons in a 165hp Franklin to get an extra 15hp out of the engine?I heard you need three items to get the 15hp,first bigger intake manifold pipes(220 hp pipes?),second a bigger jet in the carb and third the high compression pistons?
I would appreciate any comments.
Thanks,
Ken.
Thanks,
Ken.
- blueldr
If my memory serves, I believe the Franklin engine compression ratio is already somewhat higher than the Continental 300 cu.in. series of engines. Changing the pistons to a part not certified in the engine would nulify the engine certification. That would be OK in an experimental registered airplane, but it would be strictly a bootleg job in a C-170. And you know how the FUZZ is always out tearing down suspect engines to check part numbers on the heads of pistons.
- Indopilot
Don't know about Franklins but have been told by a guy that did it, that putting C-85 domed pistoms in our O-300's really makes them sit up and snort. But like you say George, it would be sick bird (ill eagle)
not to mention probably agravate the cracking problem the old 0-300 cylinders have. Brian
52 170B s/n 20446
56 172 s/n 28162
Echo Weed eater, Jezebeel
56 172 s/n 28162
c-85 pistons
Looking for technical information on c145 or o-300.
How much does the c-85 pistons increase the compression ratio for
static and dynamic? What is the combustion chamber volume?
I do not want to try to reinvent the wheel. Any help would be appreciated.
