Source for 2024-T4 Alclad sheet
Need to repair a little corrosion. The 100 Service Manual calls for 2024-T4 Alclad aluminum about 0.073 thick. Need roughly 2' X 2'. Does not appear on Aircraft Spruce Website. Can anyone recommend a source for this material?? Muchos Gracias, Chuck
- lowNslow
What part of the airplane (skin) are you repairing?
See if you can get your hands on a copy of AC43-13.
T3 = solution heat-treated and cold-worked by the
flattening or straightening operation (this is what you
get when you buy a sheet from Aircraft Spruce).
T4 = Solution heat-treated and naturally aged.
T42 = End user heat-treated from any previous
temper.
I'm 90+ % certain T3 is allowed as a substitute for T-4,
as long as standard bend radii, etc. are adhered to.
If you can't form the replacement part in T3 without
exceeding limits, you get to fabricate it out of O (annealed)
2024 and have it heat-treated to T-42.
FWIW, the mechanical properties of T3 and T4 are very close.
temper.
Bela P. Havasreti
'54 C-180
'54 C-180
Thank you, gentlemen.
Actually, I am repairing the right front wing spar in the area of the fuel tank iaw the 100 Service Manual, Structural Repair, Wing, Figure 19-6, Sheet 2. This illustration calls for both T3 and T4 material. I agree with Bela completely and that was my escape route in the event I cannot locate T4. Will substitue T3 because with all the doublers and sixty plus rivets, the repair will be substantially stronger than the original spar. Just prefer not to arouse the Feds
unnecessarily
. Thanks again for the comments.
Chuck
Chuck
- FredM
The company I work for gets their aluminum sheet from future metals http://WWW.futuremetals.com. They will cut it to size for you and also offer heat treating services. They are reasonably priced.
Fred L. Mahan
51 C170A N1289D
51 C170A N1289D
Chuck if you have a tough time trying to locate a piece I could shear ya off a piece of 2024t3 from work, allthough 2X2 is a little tough to fit in the lunch box
Vic
N2609V
48 Ragwing
12N Aeroflex
Andover NJ
N2609V
48 Ragwing
12N Aeroflex
Andover NJ
- n1410d
Give these folks a try. They are at Oshkosh every year and pretty nice to deal with.
http://www.airpartsinc.com/
2024 T4
Here is a great place for all kinds of stuff and the alum your looking for.
McMaster-Carr
Phone 630 600-3600
email: atl.sales@McMaster-Carr.com
Be sure you ck for a location near you for a freight savings.
Fred at KY35, Welcome Field, KY N8109A
McMaster-Carr
Phone 630 600-3600
You might try your local sheet metal fabrication shop. Look in the yellow pages under sheet metal & maybe also under kitchen equipment (commercial). They might not have any in stock but could probably get you some. You might have to buy somewhat more than you really want though. Might as well buy from Spruce or wicks in that case. They both list 2024-T3 (but not T-4) in their catalogs.
OK, Guys. Help me here. If I wasn't looking for it it'd pop right out at me. In the EAA Sport Aviation mags I know I"ve recently seen that ad for the sheet metal supplier that has the sweet little old lady standing in a spool of sheet-aluminum. Who is that? And I imagine they'll have a supply of T-4 they'll sell.
"In loving memeory of Ethel 7/27/14 - 4/27/97"gahorn wrote:OK, Guys. Help me here. If I wasn't looking for it it'd pop right out at me. In the EAA Sport Aviation mags I know I"ve recently seen that ad for the sheet metal supplier that has the sweet little old lady standing in a spool of sheet-aluminum. Who is that? And I imagine they'll have a supply of T-4 they'll sell.
Their ad sez (top line)
"Aircraft Aluminum 2024 T3 Alclad...." no mention of T4
- johneeb
Re: Source for 2024-T4 Alclad sheet
N170CT,N170CT wrote:Need to repair a little corrosion. The 100 Service Manual calls for 2024-T4 Alclad aluminum about 0.073 thick. Need roughly 2' X 2'. Does not appear on Aircraft Spruce Website. Can anyone recommend a source for this material?? Muchos Gracias, Chuck
I asked a friend who owns a steel supply company for a source of 2024-T4 Aluminum and he came up with Metal Express.
http://www.metalexpress.net/cgi-bin/ind ... 894f37d38d
I looked through there site and found 2024-t4, but not in your demensions. My friend said that they maybe able to fill your order even though your demensions are not mentioned in their catalog.
Johneb
