'48 Bent Landing gear
57tbird
Post by 57tbird »
Is there a "shim" available for the '48 landing gear to correct misaligned axles? Gary Granfors :roll:
Misaligned axles? Do you mean to correct for wheel alignment? (Ans: yes. See the 100 Series Service Manual, or search the topic here in the forums.)
To correct a bent landing gear? No.
Indopilot
Post by Indopilot »
If it is bent, you might check with Tom at Xpmods to see if he has approval to repair them. Brian
52 170B s/n 20446
56 172 s/n 28162
Echo Weed eater, Jezebeel
Robert Eilers
48 Bent Landing Gear
Post by Robert Eilers »
gahorn,
Where can I obtain a copy of the 100 series service manual? Actually, I need a service manual appropriate for my 52 C170B. Does the service manual contain a description of the Cleveland brake system, parts, etc.? I also need to locate the O300 overhaul manual and parts manuals.
The overhaul manual for the C-145/O-300 is available from Univair, Spruce, and McCurtain Technologies (in CD format).
The Service Manual is available from Cessna (if you want the most recent revision) or from Univair or Spruce if you want the one applicable only to 1962 and Prior models (but it will not address the Cleveland brakes, and will only barely mention the 170 in the landing gear alignment section.) If you want service info for the Cleveland brakes, you should contact them for their free pamphlet. http://www.parker.com/ag/wbd (has a pull-down menu under "Literature" which contains a maintenance manual in pdf format) or email: techhelp@parker.com
(Parker Hannifin Corp., Aircraft Wheel & Brake Div., 800-272-5464)
mit
Post by mit »
You can buy the eng manuals from Continental also.
