Prop bolt part nos
- sanships
Prop bolt part nos
The parts catalogs do not mention the part number for the prop bolts on page 145 fig 84. please help!
Alvin Sandoval RPVM Cebu, Philippines
1952 170b, RP-C399, SN. 25287
2001 Robinson R22BII
Alvin, I think the airplanes prior to sn 25373 had as standard equpment, wood propellers. Airplanes subsequent to that sn, had metal propellers. I believe that is the actual intent of that notation.
Although the "standard" might have been wood, ... in actual practice most airplanes were delivered with the optional metal props. I believe the bolts mentioned are correct for your installation (if you have the 8-bolt prop and also have the illustrated spinner....otherwise you'll need to adjust for that.)
