Quick Drain for IO-360 Needed
4-Shipp
Post by 4-Shipp »
I recently had to remove a leaking quick drain (oil sump) from an IO-360. It is an Autovalve PN BJ060AH4S. The top seal was shot and needs replacement. I called Autovalve and they said the valve is not a feild repariable item. Unfortunately the valve in question is no longer produced but they will be happy to make a one-time produciton run for about $450 (ouch!).
I need an approved quick drain with 1" x 20 thread to replace mine. anyone have any suggestins? Much thanks!
Bruce
Bruce Shipp
tshort
Post by tshort »
Bruce-
I have a quickdrain valve that I bought for the IO-360 on my skyhawk that I ended up not needing as it already had one.
I think it is the P5000 (scroll down here http://www.sacskyranch.com/acatalog/Sac ... es_53.html )
Not a 1" - is that what you meant?
Let me know if you're interested.
Thomas
Thomas Short
1948 C170 N3949V
RV-8 wings in progress
Indianapolis (KUMP)
4-Shipp
Post by 4-Shipp »
Thanks, Thomas. Yes, I need the 1" diameter 18 thread valve. The P5000 won't work but I think the F10 at the top of the page looks like it is just what I need. Thanks for the link as a google search turned up nothing. I'll give these folks a call after Christmas.
Bruce
Bruce Shipp
Bruce, according to their catalog, Wag Aero (800-558-6868) says the Cont. IO-360 engine has a 5/8" -18 drain (CAT # 770-000). The O-300 uses the 1"-18 drain (CAT # 771-000). In any case, the SAF-AIR brand is priced approx. $59. Wag Aero is one of our supporters.
I have the SAF-AIR and like it very much, as it has a short nipple on it which accepts a 3/8" piece of tubing to drain the oil into a bucket, yet the push-and-twist function locks it in place.
4-Shipp
Post by 4-Shipp »
Yes, George - you are correct. I have seen the same info, hence my solicitation for assistance here. Never the less, my IO-360 has a 1" hole in the bottom of the oil sump. The plug I got to replace the quick drain came out of an identical sump from a local shop.
Thanks again to all for the help.
Bruce
Bruce Shipp
tshort
Post by tshort »
I guess I didn't realize you were referring to a Continental - mine is a lycoming!
Good luck finding the part.
Thomas
Thomas Short
1948 C170 N3949V
Indianapolis (KUMP)
4-Shipp wrote:Yes, George - you are correct. I have seen the same info, hence my solicitation for assistance here. Never the less, my IO-360 has a 1" hole in the bottom of the oil sump. The plug I got to replace the quick drain came out of an identical sump from a local shop.
Bruce
Well, in that case, it should be a simple matter to justo order one as if you intended to install it in a O-300 and the size/thread count should work for you?
tshort
You had a Skyhawk with a LYCOMING IO-360 ???
tshort
Post by tshort »
Still do - it's a '97 R model. 160hp IO-360.
Not gonna sell it until I'm signed off and comfortable in the taildragger...
Thomas
Thomas Short
1948 C170 N3949V
Indianapolis (KUMP)
Well dip me in ---- and call me stinky! I didn't know about those new airplanes. When I saw that they had Lycoming 360 cu/in engines, I assumed they were straight valve engines of 180 HP
I don't believe I've ever seen one.
Thanks for straightening me out.
