Fuel venting
Fuel venting
While training for the commercial PTS flight maneuvers I noted a quanity of fuel venting from the fuel tank vent. The smell was quite pronounced the other day and when we returned the cabin top assembly and fuselage were stained. This never happens with "routine" maneuvers. Is this normal or do I have an undetected problem? Would it help to fly these maneuvers with less than full tanks?
Jim
Jim
Let me guess, Lazy eights and or wing overs. One of the reasons why I dont use car gas. What model 170?
Vic
N2609V
48 Ragwing
12N Aeroflex
Andover NJ
N2609V
48 Ragwing
12N Aeroflex
Andover NJ
- blueldr
If you get a pronounced fuel ogor in the cabin it is time to inspect the hoses on the cross cabin fuel vent line. This line is right behind the windshield and between the top fusealage skin and the headliner. It runs between the two wing tanks and vents overboard via the goose neck on the top of the cabin. When the fuel tanks are relatively full and the aircraft is nosed down, this vent line will flood with fuel. There are four connector hoses on this line and if they are deteriorated they will leak fuel into the cabin above the headliner and can create a real fire danger. Even a very small leak will cause a very strong fuel odor in the cabin. Inspection is relatively easy by detaching the headliner at the front end and exposing the vent line and the connector hoses.
Fuel venting
Thanks for the responses. My 170 is a 1949 A model and I have been burning auto fuel. Problem? Ya the manuvers are the Chandelle, Lazy eights etc. I will pull the headliner down and inspect the hose but what about all the fuel on the outside? The gas caps are new and are working normally.
Jim
Jim
Jim
I haven't practiced those maneuvers in my 170 and there for haven't had the issue that you have had. I can see how this would happen with full fuel tanks and even less and wouldn't worry about it if you are sure the fuel is venting out the outside of the aircraft.
You may want to insure that the vent is open to both tanks. One way I can think of to do this is to blow some air in the vent will listening at each fuel cap. This would only prove that the vent is open but not how much but it's a start.
fuel smell
As BL said the hose and clamps connecting the tank vent lines do leak after 50+ years of faithful service. Mine did at the 50 year mark, and was only noticed with totally full tanks.
Not too hard to replace yourself.
Cheers Eric
Cheers Eric
Fuel Venting
Thanks to everyone for the suggestions. The hose are not quite 50 yoa but I will check them and the cap vents. Will also fly Sunday with half fuel and see what happens.
Jim
Jim
fuel venting
I go up routinely, several times a month and do a series of coordinated turns. I also do turns around a point, etc, just to keep the joints excercised. I have not noticed any fuel venting (smells) or loss of fuel. I have found it useful to download my flights from my Garmin onto my Mapsource to see exactly how my profiles went. It is a great "after event' tool.
Today I was flying to fly (don't we all ?) and got engaged by a Cherokee. After a few wing overs and spirals to lose him I didn't notice any odors, I had 1/2 tanks. I later fuel up to full at one of my local airports, on the way back that darn Cherokee was coming straight for me, after a few Min's of using all approved maneuvers
I got a firing solution and had some odor of fuel but dissipated a few moments later as for the remainder of the flight, my coordination has been improving so the fuel odor along with some other odors is less prevalent these days.
Name and adress withheld
Vic
N2609V
48 Ragwing
12N Aeroflex
Andover NJ
N2609V
48 Ragwing
12N Aeroflex
Andover NJ
- blueldr
