Aircraft evaluations during purchase
I've been asked a few questions by a member who is looking to buy an airplane, and it has come up that his seller is unwilling to allow an unknown mechanic (the buyer's) to perform a complete annual on the aircraft. I want to reaffirm that most people only want to purchase airplanes if they are airworthy and that there is only one inspection that certifies that condition... an Annual Inspection. If the seller is unwilling to allow a buyer to inspect for that status then PASS UP that airplane! If the seller is merely nervous about a strange mechanic (aren't they ALL strange? :wink: ) then tell the seller HE or HIS MECHANIC can be present during the inspection. Doh. (I can't fathom anyone going thru with a purchase that does not have a full understanding of the airworthiness of what they are buying.)
The next question was "What is a fresh overhaul worth? Is it worth as much as the overhaul costs?"
Answer: NO!
Is an airplane with a worn out engine (or one that is at TBO but "running great!" worth as much as a mid-time engine? Of course not!)
Airplanes are evaluated as if they are six months after an annual inspection, and as if the engines are at mid-life. In the case of a C-145/O-300 that would be a 800 hour engine. Engine overhauls cost about $20K (some more, but that's a good estimate of a complete engine rebuild including accys.) That's about $12.50 per hour of operation. So a fresh overhaul engine would only add half the cost of a 800 hr engine, or about $10K to the value of the airplane. Similarly, an engine at TBO ... REGARDLESS of how "great" it's running, will subtract about $10K from the average airplane's value.
Remember: Evaluate the airplane without regard to engine time, then determine how mush to add/subtract for actual engine time.
What about "top overhauls"? Fresh cylinders on an engine that is at TBO is still an engine due for overhaul. It's merely been repaired. I wouldn't give you anything more for it, as the engine still needs overhaul. The owner has spent his money on cylinders merely so it could be transported to the place of sale. He probably put the least expensive, used cylinders on it as he could (and that's probably what he did despite his claims unless he has new sales receipts for new cylinders/pistons with serial numbers that match the ones installed on the engine.) Here's where "haggling" comes to play. If I felt good about the airplane otherwise, I might give him some additional value for those new cylinders, but not more than half of what I could buy them for ...not necessarily half of what he paid for them. (Should I be penalized because he didn't know how to shop for cylinders? I"d not give him more than half because that engine still needs overhaul and those cylinders are now "used" cylinders.)
(Note: If you are the seller, do not overhaul an engine for the sale. You will not get your money back, you'll only get half of it. Take the diminished value of the old engine and let the new buyer get his engine where he wants.)
The majority of engines that are overhauled in order to sell the airplane are "overhauled" (repaired actually) on a budget. If I am buying an airplane I want it to be me who determines the quality of the overhaul, not someone else. However, having said that,.... if an airplane is sitting on the ramp for sale, and it's engine has been overhauled by a reputable shop and looks it, then I'll be satisfied with allowing value to be added at the rate of $12.50/hr up to the 800-hr mid-life point (and likewise subtract $12.50/hr for every hour past mid-life.)
The same goes for fresh paint/interior. Those items might encourage me to add value because they're well executed, but they may also be a complete loss for a seller who put a Piper paint scheme on a Cessna. And the paint is also suspect because I don't know how much hail damage it may be hiding. (I like polished airplanes, heh-heh.) You can look at the paint at an oblique angle and sometimes see hail, but another good thing to do is look inside the wing/tail and open up the cabin headliner and look at the cabin roof for the little "bumps" that indicate hail damage. Subtract LOTS of money from that airplane and be especially suspicious of all the control surfaces which may have to be completely reskinned or replaced. (Bondo is not allowed on control surfaces.)
Remember, average airplanes is where we begin the evaluation process. An average airplane has only minor squawks, no serious airworthiness issues, has a 6-month old annual, and a 800 hour engine. (It also has an 800 hr prop, but most buyers/sellers forget that.)
Hope this helps.
wingnut
Re: Aircraft evaluations during purchase
Post by wingnut »
I agree with everything George has said, but would add this;
Engine overhaul, new paint, new interior, and mechanical/systems overhaul/maintenance is a normal part of long term aircraft ownership. Those are all items that are more easily
"appraised" than the often overlooked structural condition of an aircraft. Corrosion and previous poorly effected repairs, or lack of necessary repairs being the primary concerns, as this can end up costing as much to correct as all the above put together. Get someone who knows the early Cessna's and that has major structural repair experience. Most AP mechanics do not have serious structural experience. The ones who do will be more inclined and mentally equipped to know where to look and evaluate what he/she finds.
Del Lehmann
Mena, Arkansas
DKent
Post by DKent »
Hi All !
What is everyone's opinion on what I call the "ten year thing" , ie: the TBO is 1600 hrs/ten years, yet I have an engine used for personal pleasure, with 800 hrs, runs great, but it has been 15 years since it was new/overhauled ? :roll:
Thanks in advance!
Dwain
I had my O-300-D overhauled in 2006, at 1750 hours SMOH. The previous o/h was in 1968, 38 years before. The oil pan had corrosion in the usual spot but none of the rest of the engine had any. Same thing with an O-470-K with a twenty year old overhaul, no corrosion. Both planes sat outside in Texas and Alaska. Lycoming engines might be a different story.
