We will be grounded for a while.
http://tfr.faa.gov/save_pages/detail_8_0798.html
8/0798 - PART 1 OF 4 AK.. FLIGHT RESTRICTIONS. FAIRBANKS, ALASKA, AUGUST 4, 2008 LOCAL. PURSUANT TO 49 USC 40103(B), THE FEDERAL AVIATION ADMINISTRATION (FAA) CLASSIFIES THE AIRSPACE DEFINED IN THIS NOTAM AS 'NATIONAL DEFENSE AIRSPACE'. ANY PERSON WHO KNOWINGLY OR WILLFULLY VIOLATES THE RULES CONCERNING OPERATIONS IN THIS AIRSPACE MAY BE SUBJECT TO CERTAIN CRIMINAL PENALTIES UNDER 49 USC 46307. PILOTS WHO DO NOT ADHERE TO THE FOLLOWING PROCEDURES MAY BE INTERCEPTED, DETAINED AND INTERVIEWED BY LAW ENFORCEMENT/USSS/SECURITY PERSONNEL. PURSUANT TO TITLE 14, SECTION 91.141 OF THE CODE OF FEDERAL REGULATIONS, AIRCRAFT FLIGHT OPERATIONS ARE PROHIBITED WITHIN A 30 NMR OF 643954N/1470606W OR THE FAI081024.8 UP TO BUT NOT INCLUDING 18000 FT MSL EFFECTIVE 0808042355 UTC (1555 LOCAL 08/04/08) UNTIL 0808050215 UTC (1815 LOCAL 08/04/08). WITHIN A 10 NMR OF 643954N/1470606W OR THE FAI081024.8 UP TO BUT NOT INCLUDING 18000 FT MSL EFFECTIVE 0808042355 UTC (1555 LOCAL 08/04/08) UNTIL 0808050215 UTC (1815 LOCAL 08/04/08). EXCEPT AS SPECIFIED BELOW AND/OR UNLESS AUTHORIZED BY ATC IN CONSULTATION WITH THE AIR TRAFFIC SECURITY COORDINATOR VIA THE DOMESTIC EVENTS NETWORK (DEN): END PART 1 OF 4. WIE UNTIL UFN. CREATED: 01 AUG 16:28 2008
PART 2 OF 4 AK.. FLIGHT RESTRICTIONS. A. ALL AIRCRAFT OPERATIONS WITHIN THE 10 NMR AREA(S) LISTED ABOVE, KNOWN AS THE INNER CORE(S), ARE PROHIBITED EXCEPT FOR: APPROVED LAW ENFORCEMENT, MILITARY AIRCRAFT DIRECTLY SUPPORTING THE UNITED STATES SECRET SERVICE (USSS) AND THE OFFICE OF THE PRESIDENT OF THE UNITED STATES, APPROVED EMERGENCY MEDICAL FLIGHTS, AND REGULARLY SCHEDULED COMMERCIAL PASSENGER AND ALL-CARGO CARRIERS OPERATING UNDER ONE OF THE FOLLOWING TSA-APPROVED STANDARD SECURITY PROGRAMS/PROCEDURES: AIRCRAFT OPERATOR STANDARD SECURITY PROGRAM (AOSSP), FULL ALL-CARGO AIRCRAFT OPERATOR STANDARD SECURITY PROGRAM (FACAOSSP), MODEL SECURITY PROGRAM (MSP), TWELVE FIVE STANDARD SECURITY PROGRAM (TFSSP) ALL CARGO, OR ALL-CARGO INTERNATIONAL SECURITY PROCEDURE (ACISP) AND ARE ARRIVING INTO AND/OR DEPARTING FROM 14 CFR PART 139 AIRPORTS. B. FOR OPERATIONS WITHIN THE AIRSPACE BETWEEN THE 10 NMR AND 30 NMR AREA(S) LISTED ABOVE, KNOWN AS END PART 2 OF 4. WIE UNTIL UFN. CREATED: 01 AUG 16:28 2008
PART 3 OF 4 AK.. FLIGHT RESTRICTIONS. THE OUTER RING(S): ALL AIRCRAFT OPERATING WITHIN THE OUTER RING(S) LISTED ABOVE ARE LIMITED TO AIRCRAFT ARRIVING OR DEPARTING LOCAL AIRFIELDS, AND WORKLOAD PERMITTING, ATC MAY AUTHORIZE TRANSIT OPERATIONS. AIRCRAFT MAY NOT LOITER. ALL AIRCRAFT MUST BE ON AN ACTIVE IFR OR VFR FLIGHT PLAN WITH A DISCRETE CODE ASSIGNED BY AN AIR TRAFFIC CONTROL (ATC) FACILITY. AIRCRAFT MUST BE SQUAWKING THE DISCRETE CODE PRIOR TO DEPARTURE AND AT ALL TIMES WHILE IN THE TFR AND MUST REMAIN IN TWO-WAY RADIO COMMUNICATIONS WITH ATC. C. FOR OPERATIONS WITHIN THIS TFR, ALL USSS VETTED AIRCRAFT OPERATORS BASED IN THE AREA AND ALL EMERGENCY/LIFE SAVING FLIGHT (MEDICAL/LAW ENFORCEMENT/FIREFIGHTING) OPERATIONS MUST COORDINATE WITH ATC PRIOR TO THEIR DEPARTURE AT 907-474-0452 TO AVOID POTENTIAL DELAYS. D. THE FOLLOWING OPERATIONS ARE NOT AUTHORIZED WITHIN THIS TFR: FLIGHT TRAINING, PRACTICE INSTRUMENT APPROACHES, AEROBATIC FLIGHT, GLIDER END PART 3 OF 4. WIE UNTIL UFN. CREATED: 01 AUG 16:28 2008
PART 4 OF 4 AK.. FLIGHT RESTRICTIONS. OPERATIONS, PARACHUTE OPERATIONS, ULTRALIGHT, HANG GLIDING, BALLOON OPERATIONS, AGRICULTURE/CROP DUSTING, ANIMAL POPULATION CONTROL FLIGHT OPERATIONS, BANNER TOWING OPERATIONS, MODEL AIRCRAFT OPERATIONS, MODEL ROCKETRY, AND UNMANNED AERIAL SYSTEMS (UAS). E. FAA RECOMMENDS THAT ALL AIRCRAFT OPERATORS CHECK NOTAMS FREQUENTLY FOR POSSIBLE CHANGES TO THIS TFR PRIOR TO OPERATIONS WITHIN THIS REGION. END PART 4 OF 4. WIE UNTIL UFN. CREATED: 01 AUG 16:28 2008
King George will be in Alaska
Re: King George will be in Alaska
Grounded for a while? Only about 2.5 hours. Thats nothing, You should be in the lower 48 were this stuff happens all the time.
