Does anybody have a weight & Balance Form for the cessna 170B ? ( or any generic one for that matter ) . I have ones for empty weight and equipment , but I want one for loaded weight ( pilot , pass , fuel , cargo ).
thanks , Andrew
Are you merely seeking an example..?? or are you seeking an actual that might apply to a specific airplane? (Your Owner's Manual has an entire section devoted to this.)
Bruce put together a very good W&B program that I use all the time. If you do a Weight and Balance search I am sure you will find it. I have not figured out how to post things on the forum yet.
Actually , I am looking for a W & B Form with blank areas to write in pilot & pass weights , fuel , and cargo . I was hoping someone had a form like this and could send me a link or something I could download a copy . Otherwise , I will make one myself and share it with anyone who wants one . Andrew
Ok, Andrew... How's this?: (again...thanx to Bruce Fenstermacher):
170 A B WT & Bal FORM.pdf
170 Fabric Winged WT & bal FORM.pdf
