Crank Timing Marks
Crank Timing Marks
I have a C-145-2 with a undampend crank (with hole). After a careful search with a magnifying glass, I found the TC mark on the prop flange. As hard as I looked I could not find any other timing marks specifically 26° and 28° BTDC for mag timing. Are these marks supposed to be on the crank?
A timing protractor is what was commonly (and intended to be) used for this job. Some of the cranks have only the TC mark, but most also have a small index-scale marked with the 26/28 degree points marked. In all cases, the darn thing is hard to accurately place into position to set the points in the mags unless a protractor is used. (It can be done, but with difficulty. Many mechanics use a dental mirror to reach around behind the spinner backing plate to align the marks with the crankcase split.)
So as difficult as setting the timing correctly ie 26 and 28 BTDC in the REAL WORLD how accurate must one be when setting the timing of the mags to get the engine to perform right.
I know the FAA correct answer is exactly 26 and 28 degress BTDC.
