Crankshaft Seal
N73087
Crankshaft Seal
Post by N73087 »
What is the part # for the C145-2 crank seal. The number listed in spruce is the same as the C85 taper shaft seal. That doesn't sound right.
mit
Re: Crankshaft Seal
Post by mit »
N73087 wrote:What is the part # for the C145-2 crank seal. The number listed in spruce is the same as the C85 taper shaft seal. That doesn't sound right.
figure 4 item 19 listed as no number then it shows 530974. felt seal 539242. Might be 539241 that is seal and felt assy. I bet that didn't help did it?????
Tim
SA530917 is the seal that i put in my C-145 at overhaul. Got that number from the Superior dealer who found it crossed to the orginal seal number 530974
zero.one.victor
Post by zero.one.victor »
The parts list from my major overhaul 3 years ago jibes with Bruce's info: crankshaft seal is p/n 530917.
PN 530917, crankshaft seal (alternate PN 539241) listed by El Reno for $31. 800-521-0333
N73087
Post by N73087 »
I ordered the 530917 seal, it should be here in a couple of days. I had a taper shaft C85 once, and that seal was not split, it just slid on over the taper, that's why I questioned the same PN for the C145.
