strut step
Re: strut step
This topic has been split. Discussions may continue in THIS thread regarding "strut steps" generally ...but actual purchase transaction discussion should look at the new thread. Please do not use the TradeMart thread for generalized discussion, as that is what THIS thread is for. Thank you.
The sales-portion of the topic has been relocated to the TradeMart at: http://www.cessna170.org/forums/viewtop ... f=7&t=8304
ptporebski
Re: strut step
Post by ptporebski »
Can anyone tell me if the strut step (either Doug's type or others) that is used on C-170 will work on the early straight tail C-172s? I have a 1959 C-172 that has no steps, either cowl or strut. For refueling on trips I carry a folding step stool that I purchased from Aircraft Spruce. It would be nice to fit my plane with these if possible. :?:
The better is the enemy of the good.
1959 C-172
ptporebski
Re: strut step
P.S. To clarify - I would consider either a permanently mounted strut step or a the removeable type like Dougs. I probably prefer the gear leg type with rubber coating as my gear legs have been repainted and are not chipped up.
1959 C-172
ptporebski
Re: strut step
P.P.S. I am a nitwit. Obviously, the gear leg step will not work on a C-172 with it's legs behind/under the wing. I am interested if anyone knows where I could get a strut step. Presently, my little stool gets me up and I put a towel over the strut and stand there while refueling if no ladder is available. I would like a step to stand on the strut.
1959 C-172
canav8
Re: strut step
Post by canav8 »
PT, have you seen one of these?
In Cessna history there has been a number of problems with Wing Strut damage and inflight failures because people stepped on the wing strut. It is highly discouraged. That was why I offered the strut step. You can convert your 172 to a conventional gear. :D Doug
52' C-170B N2713D Ser #25255
Re: strut step
Stepping on the strut immediately ADJACENT to the fuselage is not harmful (except to paint.) The strut in
that area is pretty beefy, and has the extrusion inside, held by the rivets/hi-loks.
Do NOT put any weight outboard where the streamline-tubing is hollow.
Robert Eilers
Re: strut step
Post by Robert Eilers »
Re: strut step
That picture of a lift strut step from dawson is ridiculous at $50. They can be made all day long for less than $5.00 in materials and about 30 minutes labor.
Re: strut step
blueldr wrote:That picture of a lift strut step from dawson is ridiculous at $50. They can be made all day long for less than $5.00 in materials and about 30 minutes labor.
Go ahead and make up a couple for me, bluEldr...I"ll pay you DOUBLE your ordinary price.... TEN dollars each! (I'll even pay shipping.) :twisted:
(They'd better not be green, tho'.) :lol:
