Starting Engines.... the Observer's Job is ...???
What is the Observers job?
Apparently this one doesn't know much about it...he's just enjoying himself...
1- Helping the pilot determine if the area is safe for engine-start. (Look for passersby, vehicles, objects (like the AvFuel sign they almost blow away....)
2- Have a FIRE EXTINGUISHER on-hand in case of a flooded-engine-fire (easily done with many radials...and cold weather starts in Cessna 170's, too!) :wink:
http://www.youtube.com/watch?v=zr2v1AiT ... re=related
Fearless Tower
Re: Starting Engines.... the Observer's Job is ...???
Post by Fearless Tower »
gahorn wrote:2- Have a FIRE EXTINGUISHER on-hand in case of a flooded-engine-fire (easily done with many radials...and cold weather starts in Cessna 170's, too!) :wink:
What's he going to do with a fire extinguisher there? See how high those engines are off the ground in that plane? Extinguisher would be about useless in that situation.
Andrew Hochhaus
N3996V - 1948 170
Totally agree on what the observer's job is, but in this case, from the wavering trees in the far background, the wing wobble on takeoff, and noise in the microphone, it was a pretty windy day, and the sign could have been wobbling anyway. The sign appears to start wobbling with the start of #2, but appears to be stable just before starting #1, then wobbled again. In fact, if you look close you can see the sign wobble a bit just before the first engine (#2) catches. It may just be an error in perspective, but it appears the sign is high enough to be out of the propwash, and I wouldn't think propwash on the pole would cause that much movement.
Even if the sign is in the propwash, it didn't "walk" into that position, so it might be considered the PIC's job to see that the airplane is positioned to avoid objects that can't be moved easily.
It appeared to me that the PIC was already in the cockpit as the aircraft was moved to the starting position, so he may have been unaware of his blast-area. Regardless, it was a poorly selected area for large aircraft starts.
A fire extinguisher should be selected which is appropriate for the job at hand. If it's a large airplane such as this one...it should me more than a simple hand-held extinguisher.... a wheeled-cart-unit with extension-hose at the least...a small fire-truck nearby if that is insufficient.
Turbine engines and aircraft with engine extinguishers have resulted in a loss-of-memory for what observers are supposed to be "observing".
Fearless Tower
gahorn wrote:A fire extinguisher should be selected which is appropriate for the job at hand. If it's a large airplane such as this one...it should me more than a simple hand-held extinguisher.... a wheeled-cart-unit with extension-hose at the least...a small fire-truck nearby if that is insufficient.
I'm just saying you'd need a pretty bloody long extension horn to do any good on that particular airframe. The only places I've seen such horns were on ships.
I did find the start of the left engine interesting. The prop cycles until about the point where you would be switching on the mags for the -1830, and it stops (like he took his finger off the starter). Then all of the sudden it fires and seems to run solid. Not the usual start I'm used to seeing in the old radials.
Andrew Hochhaus
N3996V - 1948 170
Fearless Tower wrote:...I'm just saying you'd need a pretty bloody long extension horn to do any good on that particular airframe. The only places I've seen such horns were on ships......
Have you never seen a liquid-halon extinguisher work? They shoot a stream about 20-feet...it can be controlled as fog or as narrow-stream with the nozzle....which is pretty effective for such work.
Regardless.... IT'S THE OBSERVERS JOB TO BE PREPARED FOR AN ENGINE FIRE WHEN STARTING ENGINES... he wasn't....and that's what I'm just saying.
gahorn wrote:.............. A fire extinguisher should be selected which is appropriate for the job at hand. If it's a large airplane such as this one...it should me more than a simple hand-held extinguisher.... a wheeled-cart-unit with extension-hose at the least...a small fire-truck nearby if that is insufficient............
So George, where should the observer, wheeled cart, or small fire truck be placed for this start?
http://www.youtube.com/watch?v=Nv9uEf9K ... re=related
Funny! I've been fooling around with airplanes for seventy years and didn't know what in hell you guys were talking about when you referred to "observers". I've always heard them called "Fire Guards".
In the Air Force, an "Observer" was a rated flight crew member.
